Fixingfarmer
Did you finally end up with the right cylinder head?
(quoted from post at 06:40:34 03/18/23) Did you finally end up with the right cylinder head?
(quoted from post at 14:06:59 03/18/23) Correct cylinder head part number is a 5S1884 with a casting number 2S2970
(quoted from post at 14:34:35 03/18/23)
(quoted from post at 20:54:15 03/18/23) For your engine you have the correct number if you can find it
that 8M0694 matches in the book. 5S1884 shows no
decompression lever assembly although there is one plug.
Does it still have a pony motor?
(quoted from post at 17:32:47 03/20/23) Decompression mechanism on 8M0694 is the difference I can
see. It has electric start you say? If it has provision for
decompression lever i think it has been swapped to electric
start. Not sure if the pictures went through but I tried once
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto150406.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto150407.jpg>
(quoted from post at 22:57:59 03/20/23)
