cav fuel pump
lewistg
This message is a reply to an archived post by simmy90 on April 14, 2011 at 08:42:51.
The original subject was "Re: cav fuel pump".
I have a mf 135 that is pumping the fuel to the crankcase also. It won't allow the fuel to get up to the injectors. Was you able to fix yours without the help of a pump shop? Any pointers....
This leak is at your CAV injector pump? Or the diaphram lifter pump? That is the one that leaks the most often. They aren't cheap, but an easy fix.
Has tractor not run for awhile? No fuel to injectors can be metering valve and/or plungers stuck. Can repair and reseal if needed, 574 893 4172 call after 7 PM if you lihe.
