Ok, questions about CC front ends,
From what I have seen, a CC4 just uses a C front axle with a spacer block to lower the pivot point and lift the front of the tractor level. Is that correct? What about the wishbone? Is it also a C wishbone with a dropped bracket or is it a unique piece?
As I understand it you could buy a CC new with both front ends and swap them out for for different duties. I assume you'd just flip the pitman arm over and change the drag link when going from one front end to the other.
Does a DC4 use the same front end parts as a CC4?
I have a CC and would like to re-configure it as a CC4 if I could find the parts.
