jamesg08
im looking at getting a new chainsaw. mainly just cutting firewood for myself and for cleanup projects... whats the best saw for the money?
How old are you ie., can you lift and operate a heavy saw for a long period of time? How big are the logs you intend to cut? Look into the Dolmar line of saws I think you will find the size and price of what you need there.
i just bought a new chainsaw this fall, dont do what i did, i cut this BIG dead tree down, i laid the saw down to get out of the road safely, and the tree fell, it come back up in the air 3 feet and over a bit on my brand new saw that has only cut three trees and crushed it flat, i never thought that would happen after years of cutting dead trees out of the bush:~(
The first question to answer is who in your neighborhood sells chainsaws? You want to deal with someone local that provides good service, free useful advice and can handle any warranty issues or future repairs. Then pick a husqvarna or stihl. Both are top quality machines, have an extensive range of products from wee to huge and should last a long time. Remember to wear safety equipment (chaps, ear/eye protection, boots) that your dealer can also supply. Cut safe!
I have had a Husquvarna for over 25 years with only chain ,bar and sprocket replacement .I would buy another,but I probably won't unless I get a small saw for triming. Mine is a 61 rancher with a 20 in. Bar.
Like Mike ,I've had a Husquvarna Rancher for over 25 years and its really done some work.One new bar and 2 new clutch sprockets.Best saw I have ever ran,used.Its still a great saw and runs good.
Husqvarna, Stihl, Echo, And Dolmar are all good saws. Keep in mind however, because of Discounters, they have all been forced to make competitive priced saws. I was a Husqvarna dealer for years and worked on all brands. Husqvarna models begining with 1 are made by Poulan. Try to buy one made in Sweden. Stihl saws are made in Viginia Beach Va. and Germany. Their competive saws are made in the US. It is good to by made in US but if you want a good saw make sure that it is made in Japan Germany or Sweden.
I see plenty of saws for sale used on Craigslist and other places. An older saw slightly used is maybe better then the new ones. I like the Stihl older models.
A pro line, not a consumer line saw. One trip to the shop costs more than the difference two grades. And all you have to show for the price of a good saw, is a repaired econo saw.
Too much oil or low grade oil is a sbad as no lube oil.
Use premium gasoline. Saws have high compression small cooling fines to get the most HP per lb. It also tends to make them melt pistons or score cylinder walls if they suffer detonation.
I have had a Echo for about 30 years, never any trouble. Before that had a Stihl and always was hard to start and keep running. Might have had a leak in the intake on the engine.
