CHARGING 2950 BATTERIES
SKYBOW
I have a 2950 that Is a bit hard to start when it is -2. I have a block heater on it overnight and a magnetic heater on the oil pan. Worked fine last winter...I guess the bateries are getting a bit tired. How do I put the charger on the batteries. Do I disconnect the leads and charge each battery separately?
There is no need to disconnect the batteries since they are in parallel on a 2950. Many older deere tractors had the 12V batteries in series to make a 24V system. On those you have to disconnect them to charge with a 12V charger.
Why do you have to disconnect the (12V) batteries when they're in series? Never heard so much foolishness as has been posted today.
Another thing to try with a 25 year old tractor is change the cables. Probably changed a few batteries over the years on it but the cables get old and lose thier conductivity. Works on my junk.
Hello Skybow.
Make sure the electrolite level is O.K.
Check the battery voltage of each battery at the battery posts.This voltage should be the same at the battery clamps.
Do you see a pattern? Check all the voltages one cable at the time, from the battery/s to the starter.
In a 12V system the battery voltage should not drop below 9.6 volts at the started lug while the engine is crancking.At 24v it should 18.2V.
If it is a 24V. system you can check individual batteres voltages while the engine is crancking and are under load. You may have a weak one.
The week battery will draw the other battery voltage down and make the engine slow to cranck. Also make sure your cold satrting aids/block and oil pan heaters, are drawing current.
Check the temperature of the block and oil pan to make sure as well.
Is the starter motor in good working order?
Is the engine getting tight?
There are many variances i just listed a few.
Good Luck..................Guido.
It's two 12's in parallel from the factory. I can't imagine why some people here are talking about 24V.
AS previously stated, disconnecting to charge batteries is daft.
Run a new (-) chassis return cable from the batteries to a starter mounting stud. The factory return through the sheet metal doesn't work worth beans.
Put battery warmers on there. Cold batteries are weak batteries.
I'd look at all the cables and connections first. Clean, etc. Mabey replace them.
Beyond that I'd probably replace the batteries if they're 5 years old or more. Not too many make it past that stage anymore.
A weak starter is another possibility...
Wehn charging, just hook the charger up. I never disconnect the cables, though I suppose one should...
If they're hooked in parallel both will charge anyway so long as the cables remain connected.
Rod
I have a 2350 and it was cranking slow last winter. New batteries didn't change that. This fall I put new cables on it. I made up my own from good heavy jumper cables. I ran both pos cables to the starter lug and both negs to the bolts mounting the starter to the engine block. I didn't like all the places between the battery box and the starter case for corrosion to inhibit current flow. It now spins fast and starts well.
If it's a Bosch starter there is a 4KW replacement for that factory 3KW unit.
If it's a Delco starter on there. You should be able to find a two hole mount for a MT41. That will wail that engine over at idle speed if the batteries are good.
Nobody has yet mentioned the good old $8.00 manual pump destroker which makes a world of difference.
It's like putting a 6V charger on a 12V battery. It will work to a point, but you'll probably never get them fully charged. Also, it may not be healthy for the batteries, but that's just speculation on my part.
On my 4020, leaving the 12V charger on overnight with all the posts hooked up does next to nothing compared to disconnecting the posts and charging each battery for a few hours.
Also, jump starting or using the battery charger boost is pretty worthless on that tractor for the same reason.
You are going to have to learn how to conenct a 12V charger to a single 12V battery.
Instead of across two 12V batteries for 24V and wonder why the batteries don't charge.
Taking the cables off does not affect charging if properly connected.
