9N 6 volt front mount. Rebuilt this tractor- new wiring harness, new generator, new cutout, new resistor block and new ammeter.With the wire from the BAT terminal on the cutout to the charge post of the ammeter, when I turn on the key the ammeter shows 10 amp charge!! Start the engine and the needle returns to zero. Switch wires on the ammeter and with the key on-10amps discharge and returns to zero when I start the engine.At the generator a voltmeter shows it generating 12 volts, but across the battery terminals very slightly over 6 volts!
Double checked all wiring using a wiring diagram that Dunk posted here. Also, checked it against a running 9N--all correct. Even switched cutouts to see if that was the problem--same results.An old Ford mechanic mentioned that I might have received a generator wound for a negative ground 6 volt system. Is that a possibility? Another suggested just switching the battery cables.
Can anyone give me a clue as to why I have to switch the wires to the ammeter to get it to show discharge when the key is on? And when the engine is running at half throttle the ammeter needle will not show a charge? Any thoughts on that? Sorry this is so long. Thanks.
