(quoted from post at 16:59:58 07/07/14) If you only need one remote then as far as I'm concerned your cheapest option is probably just buying a single spool double acting remote valve WITH detents, possibly from this site. You can go with the adapter plate and surplus center valve... and that might be a better route if you needed more than two spools... but for one valve I think the OEM style kit provided is generally a cleaner, easier install. If you go with external parts you need to know how to plumb it and the cost of custom hoses can add up too.
Rod
