John Smith8N
Thought I would relate how a simple thing kicked my butt on a 6V front mount. I can't seem to be able to make a long story short, so here goes. Guru's will spot the problem right away. Rookies might, too. Had a friend call me yesterday to help him get his 2N started. He hasn't been able to get it to run since he did his spring tune-up and maintenance. The tractor is a '46 2N that was completely refurbished about 10 years ago. I don't say restored because it's painted 8N colors, but otherwise it's a near mint all original '46. So, I loaded up a small bag with a few tools and my ziplock bag containing a rebuilt front distributor/coil assembly. Nine times out of ten, swapping that good front mount distributor onto a non runner will get it going. First question when I got there was "what did you do to it?". His answer: new points, condenser, rotor, spark plugs, oil change, new coolant, replaced the water pump, new battery and cables. "Won't hit a lick?" "Nope". Ok, so I'll put my distributor on before ever ever hit the starter button. Got that done, made sure the plug wires were on right, stabbe it with a test light to be sure we had juice, and sniffed inside the gas tank. It was last year's gas but still smelled ok. Pour in a couple of gallons of fresh gas anyway. Pulled the air inlet tube off the carb so we could see what was going on there. Flipped the switch on, hit the starter button, and watched the amp gage swing indicating we had power and the points were opening and closing. Noticed he had wired the 2 terminal amp gage backwards because it showed charge rather than discharge. Not a problem. Everything else seems fine. But it wouldn't start or even try to fire. He said "I told you I put the points in right". Did you flood it before and get the plugs wet? Pulled all the plugs out. Clean and dry. Put a couple loose plugs on the wires and cranked it over. Got spark at the plugs as expected. Put everything back together, put the battery charger on it for some extra ooomph, squirted some fresh gas directly into the carb and tried it again. It would fire feebly a couple times but not enough to get it going. The tractor was in the front half of the chicken coop. It's 96 degrees outside and humid and the stupid rooster would not stop that annoying crowing even though the sun has been up for hours. After cranking and fighting it another 20 minutes I told him to get his pickup and a strap, and drag the thing up to where my trailer was parked. I'll take it home where I have decent tools and parts and figure out what's going on.
Got it home and in the quiet shop under the ceiling fan. Checked everything over again, twice. Pulled the carb drain plug and let some gas run through to make sure the fresh stuff was getting there. Tried starting it again and it would hit on one or two cylinders but never enough to keep going. It would sometimes hit enough to kick the starter drive out but that's all. Now, I don't believe in pull starting a tractor. If it won't start on it's own there's something wrong and it needs to be fixed. Pulling it ain't going to fix the problem. But, it's still hot as the devil out there, I'm tired and sweaty, and I'm convinced if it ever got going one time it could clear all the cobwebs out and be ok. So I got the wife to get on an 8N (not happily), connected a tow strap, and we headed out. For a hundred feet or so it sputtered and then it finally took off. Running rough, but running. No smoke or noises. I drove it around for a few minutes letting it warm up. Throttle response was poor, slow like it had retarded timing. But I know it's not retarded. Not really missing, I'm sure all 4 cylinders are firing, but it's just generally rough. Messed with the carb to find that turning the main mixture needle in made it want to die, and backing it out let the pressure off the spring and the needle got loose. Crappy carb. Backed it into the shop, and swapped the carb for a rebuilt one from a ziplock bag. Buttoned it up, turned on the gas, and hit the starter button. Same old same old. Would hit a few times but would not start. WTF? And then, the light bulb finally lit up over my head like in the cartoons. One of those slap your forehead moments. Dummy....how did you miss that? Five minutes of work later I turned the key, hit the starter button, and it fired up instantly and ran like a new tractor. Went for a ride and got crisp throttle response and smooth power. Shut it down, hit the button, and it starts up on the first turn and just purrs. So, what was the problem? For some strange reason this tractor had a major reaction to a simple problem that many other tractors seem to be able to live with without noticeable running or starting issues. I don't know why this one reacted so badly. Got it yet?
