I have a '52 8N side mount distributor. I just replaced the 6v coil due to my over aggressive tightening of the negative post and breaking it. I now have the new coil installed (pretty proud of getting the old bracket off without busting something else). I have primary current to the distributor as I checked it with the multimeter but am not getting spark to the plugs (I used a spark tester and not an old plug and checked all 4). How do I check to know the points are opening properly or if I'm not getting current between the secondary wiring in the coil and the distributor? Should I purchase a tester with a light that will flash as the points open and close? Battery is good as it tests over 6volts on meter and has been on a tender.
