chinese tractor /manuals?
Anonymous-0
Has any1 had anything to do with Task Master/Trojan 432....32 hp 3cil.
Problem...Hydraulics are more than slow to pick up !Seems to have air in the system, Can this be caused by a restricted intake fillter?
There are 2 small leaks on the bucket lift ram.
Codger not the tractor guy!
Troble with a chinese tractor, thats funny, why dont you go down to the local tractor shop that has been there for 50 years and see if they can help you out.
(quoted from post at 18:53:10 12/12/08)
Dude... Gotta lot of balls asking this bunch for help. Made in China and sold by Mexico. If you think it's air, try and bleed it. If that doesn't work, change your handle and ask the question again as a generic hydraulic question ;).
Good Luck.
Dave
Got to agree with you Dave. I don't remember this forum being "the Land of Almost Right". Think that is on another site.
Got me curious so I googled a little and found some old forums that talked about these things being poorly QC'd with loose belts, bolts, and hoses (and slow reacting hydraulics). Maybe you just have air in the system. Didn't find much customer support while googling.
Good luck.
Dave
As you can see, not a lot of love lost for Chinese tractors on this forum. Google Chinese tractor forum, and you'll find a bunch of more sympathetic types.
I don't know about the tractors, but I had been thinking about an ATV to help out around the place but couldn't (and didn't want to) afford the 7-8k+ Euro price tags. The chinese ones hang at 4k and less. Finally found a 3 yr old chinese one on ebay for less than 1k and got it with the idea of it working or putting it back on ebay. Needed to fix a couple of things, but it's doing everything I want and more (and fun too). The parts I needed for it, after a little googling, were japanese (Yamaha) parts. Love or hate, it does the job and the new price for the machine is less than a third the price of the same thing that says Yamaha. May not be long before any pickup you can find will be china made.........
I don't like the quality of chinese tractors either, but, you got one--sounds like your pump is restricted or sucking air, or bad pump.. I have worked on a few & regardless of brand,most seem to use a screen in the hyd. sump that will stop up from pieces of rubber/seals. if not this type, you may be lucky with an in-line type filter--trace out suction line to pump] problem with screen is it would rupture & pump is trashed out from the junk.hope this helps--Paul
Thanks for the replys, I did not buy it, just
use it.[ another story] I was more interested
to find a sorce of info on this machine.
I think the pump is in the tank,[oil] so Icant see how it could get air? I suspect that it has not had a proper maintainance scedual, 3 yrs old I think? This tractor is on the size of The 275
international [small size]
The name task master dose not realy tell who makes the thing ,I think they just change the paint & new name.??
Later,,,,Al Hunt
Good luck on the manual. The chinese (brand) quad I have has a website that you can download service and parts manuals. However......... If you don't know what you are doing to begin with and/or know what parts are and how they go together by looking at pictures, the text (translation) will drive you nuts. Maybe google up a dealer and start making phone calls (speaking spanish could be a plus).
Dave
