chisel plow ?
Timis
Looking for some advise on a piece of ground I farm. Did notill beans last year going to corn, corn needs to be tilled in our area. I have a chisel plow, light disc, and field cultivator. I'd like to run the chisel this spring fairly shallow like 6 inches to throw dirt then finish with either my cultivator or disc. My disc wont bury much so thats why I was thinking bout the chisel - thinking if I run it shallow - kinda like a high clearance field cultivator I wont make too many lumps.
Always a good idea to chisel a bit more shallow in the Spring- turns up less cold soil. Here it is better to use a field cultivator for secondary tillage. Discs are a good machine if you want to pack the soil. Never understand why the wannabees think they need a tractor, plow, disc, and a FC is not on the radar. Discs have their use in cutting sod after plowing.....look at what works for the full-time farmers- there is a reason the majority use the FC after the moldboard plow, or more commonly- the disc chisel. Going through the south half of MN...see very few fields plowed.
So you think I'd be OK running the chisel shallow --thats what I'm thinking basically like my fieldcultivator but better clearance and move a little more dirt. My fieldcultivator is a IH 4500 x 28 ft and it struggles with bean stubble plugging the harrow- if I can get some dirt on top I think the harrow will let the trash go past. My disc is pretty light 21 ft x 7.5 in spacing - 18 in blades -so it does ok finishing - but i agree that I probably dont want to put 2 no -no's together for spring tillage.
You are talking two classes of implements. Unless you have a plowing disc, capable of cutting 8-10 inches deep on untilled crop land- it is a secondary tillage machine, vs the chisel plow , which, like a moldboard plow, is a primary tillage tool. ie- primary tillage is done after the crop is harvested, secondary tillage is done after primary, to prepare the seedbed for the next year"s crop. If your soil is more clay than sand, and your tillage is done in the Spring, you want it to be more shallow than Fall tillage, because tillage on clay in the Spring will create hard soil lumps that are not conducive to making a seedbed that allows new sprouts to grow. Simple terms- the soil is like a brick!
Beans last year, should not be much in way of stalks left to cause problems. Here in the clay of Ohio I would first try the field cultivator and if too many problems go with disk for a first time over and for a second time over it would be a field cultivator and with the size of those implements I know they are way heavier than anything I ever had.
I know it's too late for you this year but I disc 6-8 inches in the fall and plant it in the spring. I have disked in the fall and field cultivated in the spring and had good results too. Beans mellow the soil really well so you don't need to go to deep. If your ground has not been hilled I'd just split the row with the planter and float on your chemical and nitrtrogen and dry. I've had great results doing that also.
The purpose of a chisel plow is to leave trash on top of the ground protecting the soil from the sun and wind, conserving moisture and preventing soil erosion. Why do you need tillage ? Dry the ground, warm it up ?
