CHISEL PLOW
B GATLING
Is ther a "rule of thumb" for the amount of horse power needed per shank of a chisel plow. Was always told 7 hp per ft for a disk but have never heard on a chisel plow.
Not sure. I just bought a 12 foot 13 shank International to pull with my 6788 that tested at 200 HP. I could have used a bigger chisel, I tried it just a little before this snow and the tractor didn't know the chisel was back there.I guess 15 hp per shank or 16.6 hp/foot is more than enough if that helps. I'd much rather have it that way than the reverse though.
Now I'm anxious for thisweather to clear up so I can chisel everything!
15 per shank/ foot is about right to start with. I have 10 shank on my 140 hp tractor, and am comfortable with that setup. Pulls easy some days; get into the compaction the chisel plow is meant to deal with & boy then you know it"s back there... So depends a little on the year and so on.
--->Paul
Granted, a chisel plow vs a disc chisel...12 foot chisel on a 4020 is fine, better on a 4240 or bigger. Just depends how fast you want to run, and how deep. 7 hp per foot on a field or finishing disc- don"t need that much. Chiseling is primary tillage. paul and Birdman are certainly in the range for current operations. Early days, with a Graham-Hoeme chisel plow, in the 50s-early 60s- hard to find a tractor that could pull a chisel wider than the tractor. HP simply was not there...but the idea of reduced tillage was fine.
That 7 HP per foot was for the early 3 point hitch chisel plows, not a disk. And that was pretty much what a 7 shank spaced on a 12" spacing took on a tractor like the Ford 5000 that was right at 70 HP on pto. That was running about 6" deep and they did not have the strength or clearance for deeper.
