(quoted from post at 08:39:01 01/07/09)
(quoted from post at 06:12:21 01/07/09) I took the gas tank off of my 600 to replace the shutoff valve. I'm thinkin' I should try to clean some of the rust out of the tank . Should I put some sand in there and shake it around ? Wonder if I can get it all back outa there. Any ideas ?? In order to still be able to use the tractor I made a plywood piece and bolted to the original tank mounts , so I could mount a small mower tank. Works GOOD, has a 1/4 in. fuel shutoff and everything.
rocks, bolts, nails,,, just cleaned and lined one,,,used rocks and they were real hard to git out so on the next 600 tank will use nails so i can use a magnet to fish'em out with,,, the fill neck is recessed into the tank and thats why its hard to shake the nails out,,, i had to reduce my wet vac hose down and come up with a flexible hose to git in the 600 tank to suck the rocks out
