Clutch won't engage
Ed Scott
Hello, I just joined the forum and have read a lot of postings. I really need you guys! I am now the new owner of a TO30 that sat neglected for ten years outside in Vermont weather. Needless to say, it isn't running. So far, I've rebuilt the head, done a valve job, rebuilt the starter, rebuilt the steering shaft, rebuilt the carb, new ignition kit, gascolator and probably a lot more I can't remember without consulting my credit card bill. I just noticed that the clutch does not engage when I put it in gear. The clutch spring is good and strong and returns back up, but when I put it in gear, I can still turn the engine over by spinning the fan (the pistons are out and the head and starter are not installed). Can someone help me understand this? Thank you.
Ed @BTV VT
I can't help you with the clutch but I'm sure you will get helpful replies. I just wanted to say that is a good little tractor. I learned to drive on a TO 30 . We also built our 40' x 120' machine shed using the 30 Ferguson to set all the poles and dig all the post holes. We have an 8n now and that Ferguson is a better tractor in my humble opinion. Hang in there and good luck.
If engine turns free, while tranny is supposed to be in gear, I would look first to see if the shifter is really engaging the gear..
