Cockshutt 30 clutch kit
Dave 45
I am looking for a clutch kit for a Cockchutt 30 which includes a pressure plate, throw out bearing, pilot bearing and clutch disc. Does anyone know where I can find this part!?
Do you have the old pressure plate and clutch disc? If you do Carolina Clutch and Brake may be able to reline the disc and rebuild the pressure plate. 1-800-374-2212
Hal
Hi Capacity BUT you have to go thru a dealer.
I Would go to Phil Heisy in southeast Penn. Here's Phil's post from the Cockshutt Oliver Board
Very knowledgable and helpful.
H MH55,
The tractor serial number is punched/stamped into the tops edge of the engine tub frame between the dipstick and the radiator. It will start with 30, space for the year, 47, 48, or 49, and another space, and then the serial number. If it is later than a 49, it will just be 30, and then the serial number.
I have many new and used parts available to you. I have all the BUDA engine parts on stock that you will need. Please let me know how I can assist you further.
Phil Heisey 215-256-8651 FAX 215-256-1203
High Capacity
