Masseyharrisnut
Used to think i was pretty good at figuring point style ignition systems out and fixing. But Im confused. Restoring a 40 right now. I put a picture of it on this forum a
while ago. Started it up a few days ago and it ran briefly then quit. Started up again right away and quit again. Would not restart. Checked a couple plugs and
found intermittent spark so decided to dig a little further. Looked at the points and decided to put new ones in. Replaced condenser and rotor as well. Coil was
new already. Tried to start and would not fire. No spark at the plugs. Tested coil and it tests good. Even put old coil on to try and no start. Checked power going
into coil and its good. Checked all plug wires and they test good. Battery is good and all cables and wiring from ignition switch are good, they are all new. Tried a
different condenser and still no spark. Put new plugs in this afternoon tested the coil again and checked voltage going into distributor from the coil and it is good.
Did a resistance check on the coil wire through to the carbon contact to the rotor and its good. Still no spark. What am I missing?????? Thanks for any help
