BarnyardEngineering
- Location
- Rochester, NY
"Comments like yours are harmful to a newbies understanding, thus worse than not helpful."Yeah, it should have felt refrigerated?
Well regardless of what JMOR says, the first solenoid you had wasn't "wrong." It simply had an additional terminal. "What do I do with the extra terminal?" would have cleared up any confusion. In this case the answer is, nothing. Leave it open.
The OP needs to clarify how he has his system set up. He said “I tested power to the solenoid and got 12 volts” is that at the small energizing terminal or the battery cable lug? You would hope there would be power at the opposite end of a battery cable which I presume is brand new. I don’t think any of us know if he has it set up to provide a ground or 12 volt power via an added push button to energize his solenoid. The only other clue we have is in reply 12 the OP says “this is not a conversion” which might indicate he is utilizing the gearshift start. That usually comes highly recommended here as it is a safety feature.I have doubled check the wiring as it’s all new since I am rebuilding every single part of the tractor, including the engine. I will replace the start switch as well just to be sure.
I tested power to the start solenoid and got 12V, but didnt get anything on the other side of the starter solenoid going to the starter and hence no power to the starter, even with the key switched over.
Unlike you, who does not know whether he has ckt 3 or ckt 4, this real vs barnyard engineer, didn’t jump to conclusions nor “rigg” some cludge. I expect that he has by now determined who to listen to.Well regardless of what JMOR says, the first solenoid you had wasn't "wrong." It simply had an additional terminal. "What do I do with the extra terminal?" would have cleared up any confusion. In this case the answer is, nothing. Leave it open.
Pins on the rotor? The rotor makes no contact (or shouldn't) with the distributor tabs except the center tab (pin) going to the coil.Well found the new distributor pins were not contacting the rotar so had no spark, had to reset the pins and ensure the gap was correct.
Hi,
Well found the new distributor pins were not contacting the rotar so had no spark, had to reset the pins and ensure the gap was correct. The engine turns over but wasnt getting cranked or lack of staying cranked. Resolved the ignition issue but still have the staying cranked, replacing the carb today since the old was still installed after rebuild.
