Shane66
I am working on a cub lo-boy, 6volt postive ground I beleive its a 66 model. I was going to bench test the coil to determine if it is a problem does anyone know what the value of resistance (ohms) is for the primary and secondary coils?
Thanks in advance,
Shane
Why don't you install it on the tractor and connect battery voltage to it. Then remove the coil wire from the cap and hold it near a good ground on the tractor while someone snaps the points open and close a few times to see if there's fire from the coil wire. You may need to rub those points with some 320 wet or dry to clean them. Hal
My experience is that the primary resistance( between the two terminals) for 6 V coils are around 1.5-1.6 ohms and the true 12 V coils are around 3.2 ohms. You can check them as the previous poster said, IF the condensor and the points are good. If you have a FAT, BLUISH-WHITE SPARK ABOUT 1/4" LONG, the coils good. If you points and /or condensor are suspect, I'd go the VOM test route and measure the resistance.
A shorted turn in either the primary or secondary won't show up with an ohmmeter test, but will kill spark.
Gerald J.
A simple low voltage ohm meter test can show if a coil is bad BUT NOT IF ITS GOOD. It can easily pass ok at low voltage but get her up to temp operating at high voltage and temperature and she can break down. The primary would be from 1.25 to 3.5 ohms or so depends on if 6 or 12 volt coil BUT IF ITS OPEN ITS BADDDDD. The HV secondary would be maybe 5k to 10 K ohms, if its open its bad but even if it shows continuity you could get breakdown at high voltage.
Hook it up to the tractor and with voltage on its input and current flowing through it (like via a good set of points wired to coils primary output) each time you interrupt that current (like if points open) a good high voltage spark should jump a distance of say 1/8 to 1/4 inch (use coil wire from coil to within 3/16 of frame) from the wires end to frame IF the coil works
John T
