Collection for sale
Top left is a Farmall H for sure with a farmhand loader, I think. Top right is a Massey Harris, I think maybe a 101 or 102. Bottom left is a co-op/cockshutt/oliver, not sure, bottom right I have no idea. If any of them run it could be a good deal, if not offer something lower.
Zach
I'd say:
Top left, Farmall H, top right is a 44/44 special Massey harris
Bottom left looks to be a co-op E3, bottom right is either a 44 or 55 standard..
Counting the louvers on the grilles of the massey's tells me they are both 44's, as the 33's had a different "arch" on the hood sides, so did the "triples"
I don't believe the grilles are tall enough to be 55's, and to the best of my recollection, there never was a row crop 55, which the upper right would be a row cropper.
The co op looks too big to be a 20, and from the looks has a 4 cylinder, so that should make it a E3, as the E4's had a 6 cylinder (also IIRC)
2 grand probably isn't too far out of line.. scrap is 220/ton here (SE lower MI), and I'd say all 4 should weigh somewhere around 4000 lbs each (the H would be a shade lighter I believe, but the loader would offset that) Major issue to looking at it as scrap price is if someone were to scrap, they'd have to take time to haul in, and have 16 tires to dispose of, as our scrapyards will have nothing to do with rubber.
I will agree however, a lesser price is easier to swallow.
Brad
Not a 35, as 35 is the only Cockshutt with both intake and exhaust on the right side. I think its an E-4 (Cockshutt 40) or 5, rather than E-3 (30)- just by the configuration and size of the sheet metal.
I agree on the ID's of the others (although I was wishing the green one was an Oliver).
Nothing scary about that Farmhnd Loader!! It is a good high lift type of loader but maby not the fastest to mount and dismount. If hyd. it should have a pto-driven hyd. pump and dedicaated valves and tank. Allan Nb. will be able to give you more information. I would use it and enjoy! Armand
Agree Farmall and co-op, don't know much about them. The top right is a 44 massey, not a special cause the fuel filler is in front of the tank, but it does have the cast front wheels of a special. The bottom right looks to me to be a 444 standard, same number of bars in the grill as the 44, 55 or 555 had one more, looks like it has the grill badge on top as a 444 and has the throttle control up by the steering wheel. Price is cheap, could part them out and make some $$$.
