Combine dying
Erik Ks farmer
Picking corn with a 540 Massey with the A4-318 Perkins, two evenings in a row the machine has up and died on me. This morning I went back to the field and the machine started, am i correct in thinking that my fuel pump is going out?
It sounds like fuel is restricted, perhaps a clogged line, filter etc..when the combine sits the fuel eventually gets where its supposed to be and it fires right up.I can't rule out fuel pump but check everything else first. If fuel isn't a problem its dying when its hot and that could be a bad coil..once the coil is cool in the morning it fires off..two distinct possibilities
I recently had a slowly worsening situation where the screen inside would slowly plug while running.after sitting everything would refill, and off it would go again.
Start with a new fuel filter, and check any screens that might be in the tank or along the way.
Very common for that to be the problem, and easy to fix.
Could be much more of course, but try the simple first!
--->Paul
My Massey 550 did the same thing a few years ago. I bought a new fuel transfer pump and while I was taking the old one off and putting the new one on I happen to look into the check valve immediately below the fuel pump. Rather than bright colored steel ball there was brown. Soybean chaff had broken through the screen in the sediment bulb and worked its way up the fuel line to the engine compartment. When the engine was off the chaff would float downward allowing fuel to the engine. When the engine was started the chaff plug would start to work its way up the fuel line getting stopped in the area of the check valve, then the engine would die. After a period of time it would start again and run for awhile. It could be your fuel pump or it could be a chaff plug that migrates up and down. I would take the fuel line off of the transfer pump, clean the check valve, then blow compressed air backward through the fuel line. Make sure the fuel line is off of the sediment bulb. I bet you will get this issue corrected. I took me several hours to figure it out. I changed the filters, bought a new transfer pump before I figured this simple problem out.
How long since you cleaned the fuel pump. buildup of dirt a possibility.The type with glass bowl on top has a fine filter,as I just found with my Fordson MD. same problem.
Had the same thing happen to my MF tractor. It would quit and after a while, 20-30 minutes, it would run fine. Changed the filters and still had the problem. A guy on the MF board told me to take the petcock apart at the bottom of fuel take and clean it. Didn't have a problem again for a few years and the tractor did it again this summer. Took the petcock out again and cleaned it and its run fine since. I run clean fuel and have a filter on my large storage tank but still I get enough foreign matter in there to clog things up. I never have a problem with my two kubota desiels just the MF.
This has been quite a few years, but sounds like the same issue I had with my IH151 combine.
I had even switched fuel pump and carb with my parts machine. It would always start and run good for a while, then start sputtering and die.
Took a while to figure out, but it ended up being a wasp had somehow found it's way into the fuel tank and would eventually get sucked into the fuel line before the fuel strainer, as soon as it died the dead wasp would float just far enough back to restart and run for a while. I finally found it when I decided to run it clear out of gas, thought maybe a chunk of rust was floating around and I would just swap tanks with the other machine.
As soon as I unscrewed the sediment bowl assembly again I saw "something" hanging part way out of the tank. Pulled him on out with a pair of needlenose pliers, had no problems at all after that. DOUG
