Compression Results
RDAllison
I gat a compression tester today!
Here are the results:
First Second
Cyl 1 110 psi 110 psi
Cyl 2 110 psi 110 psi
Cyl 3 110 psi 110 psi
Cyl 4 115 psi 114 psi
Are these numbers to high? The spark plugs are very black. Is that carbon buildup, and if so dose that mean air problem?
<a href="http://s296.photobucket.com/albums/mm164/mdrfarms/tractor/?action=view&current=IMG_7261.jpg" target="_blank">
IMG_7261.jpg" border="0" alt="Photobucket
</a>
Compression gives you 'Braggin Rights!' I suggest you change your plugs to the all famous Autolite '437', and check your carb settings, see Dell's advice in the 'archives'. HTH b
Yes you have an air problem,but it that your motor is being flooded with gas. These carbs are so good that when they don't vent or the fuel shutoff under the float sticks your motor sucks so much gas thru it it can't burn it all and blows it out the tail pipe.Carb adjustment is impossible(under a load).When I opened mine up it was brand new everything looked good,but upper passages were clogged.Compressed air cleaned them out and it doesn't even sound like the same tractor.Start by cleaning the filter right before the fuel shutoff valve on the carb.
Allison........thems "braggin' numbers", new compression is about 125psi, rebuild time 90psi. Good running engine about 110psi.
Them sparkies are sooty not carboned. Carbon is hard greyish, tannish, deposits. Yer soot is soft from TOO RICH. I suspect too rich idlemix.
The idlemix is the side-pointing needle which is BASSACKWARDS, out for lean, IN for ENRICH. Leave yer down-pointing mainjet alone, it ain't causing soot.
I'd adjust yer side-pointing idlemix 1/8-turn CCW. That should speed up yer engine and lean-out yer mixture. Iff'n it don't reduce yer soot, leanner-out 'nutter' 1/8-turn. You need CLEAN sparkies to detect soot-level and about 5-min of idle time ...or... go brushhog for 1-hr to burn the soot off and then about 5-min of idle time. Pull yer sparkies and take a look, my eyeballs don't see that far. (grin) report back ........Dell yer self-appointed sparkie-meister
Ok, guys, I have magnified the pic of them plugs times 3.
I don't see any normal plug parts on them!!
What gives?
(quoted from post at 23:03:17 05/14/09) Ok, guys, I have magnified the pic of them plugs times 3.
What gives?
Just needed a bit of gamma correction, Dunk.
Allison.......oh shoot, you gotta Zenith carb...from my Zenith notes:
"Zenith Carburetor -- Initial setting----T screw on bottom turn out 2 1/2 turns-----top idle screw out 3/4 turn. Let warm up, then on 3/4 throttle, turn bottom T screw in till engine fades, then out till smooth..(In = Rich, out = lean) Set idle (top screw) for smooth low idle..Farmers Service Inc. 330-482-4180 Carb. # 13876"
Every carb needs to be adjusted to the engine it is mounted on. But it looks like you have mixture adjust problem. .....Dell, who hates Zenith's
