Compression test
grandpa Love
Ford 2n. No starter, governor, battery,carb..... before I go buying parts can I use a hand crank to check compression? If numbers are good I can get parts from Tracy Brown!! Will a crank from a Cub or Allis B work? Thanks!
I have never tried that but I cant see why it cannot be done. all plugs are removed and you only need 5 revolutions, so it would be a lot easier than cranking with plugs in it. plus you need to spin it over in 5 complete circles not half pulls. reminds me of the neighbour, ne would get mad at his case and just spin it over like crazy with the crank. plus the other advantage is its a small engine so I say its a yes. don't know about the cranks.
I've never tried running a compression test with a hand crank.
I guess it could be done,but you'd have to crank it through pretty fast and try to give each cylinder the same number of cranks and speed.
I would probably go more for feel and sound than trying to get a reading on a gauge.
Pull all the plugs, put one in at a time, turn it through feeling the resistance of each cylinder, listen for air hissing out the exhaust or intake. Then do it again with a spoon of oil in each cylinder. If the pressure improves, the rings are leaking. But if it's been sitting a long time the cylinders will be dry, so oil will probably give a big improvement.
Running a compression test on an engine that has not been run in a few years is not real conclusive. Dry rings, stuck valves, rusty valve seats will add up to low or no compression. All will improve once it's been run.
Other things to look for, deal killers like freeze cracked or damaged block or case, broken castings, missing parts (but you already know some are missing).
Buying anything not running or all there, my opinion it reduces it to scrap value unless it's something rare.
Can't answer about the cranks, but could probably be modified.
I've got a box full of parts on the way for a different N. Ordered from YT! Not sure how much I want to put in this one if the compression is low.....
It would probably work however I would have someone watching the gauge while the other cranks. When the pressure stops going up that should be the compression.
Borrow a "leakdown tester" from one of the autoparts store that rents tools.
It won't be particularly accurate on an engine that hasn't been running, but, then again neither will a compression test.
A "leakdown tester" flows a measured flow of air into the cylinder being tested, and in addition to a % reading on a gauge you will be able to here air leaking into the intake manifold or exhaust manifold past stuck or none-seating valves, or air coming out the oil fill tube indicates rind and/or piston problems.
ONE example of a leakdown tester
Grandpa,
I've never done a compression test with a crank.
Let us know how it works.
What if you pulled the tractor? Usually it takes multiple cranks to get full compression.
(quoted from post at 23:00:12 06/28/19) Ford 2n. No starter, governor, battery,carb..... before I go buying parts can I use a hand crank to check compression? If numbers are good I can get parts from Tracy Brown!! Will a crank from a Cub or Allis B work? Thanks!
I bought a non-running Ferguson last summer. I took the crank from my running Fergie with me. Cranked it over to see if it was free, felt 4 compression strokes, bought it, had it hauled home, had it running the next day after about a 1/2 hours tinkering.
No, I didn't get any compression numbers but did feel very equal compression resistance when hand cranking. Still haven't checked it. It runs great.
no reason it won't work, may not find it;s true compression but will let you know if ones way lower then the rest.
If you have a compression tester that screws into the spark plig hole then you could do like several have said. The tester I had you just put it onto the hole and pushed to get it to stay there as with any amount od pressure it would push your hand back and leak out all the pressure and if you were not where you could hold the tester and hit the starter at the same time you had to have a helper but engine could not be moving for you to walk beside it while testing. AndI would guess that Grandpa does not have a belt pully to fit on his Fords. And don't know if either the Moline or Oliver have the pulley option.
