Changed the oil, filter, and sparkies in my 51 8n today and decided to check the compression.
68, 90, 80, 95 dry
70, 90, 85, 100 wet
Oil pressure is 40psi at full throttle and 30ish at idle. Lots of blow back out the oil filler. Been this way since I bought it early this year and I probably have 50 or so hours on it.
After the maintenance I did some plowing and disc'ing. Everything ran nice. Good power, etc. etc.
So my question is, with those numbers and symptoms, I got some engine work that needs to be done, but can it be done later rather than sooner?
Am I hurting anything if I do nothing? Like I said, other than the annoying blowback, it runs pretty nice.
Thanks!
68, 90, 80, 95 dry
70, 90, 85, 100 wet
Thanks!
