Anonymous-0
how much do you gain by adding more compression to the motor?
Might be pumping losses on a single cylinder but multi cylinders the higher the compression the harder the piston drives down the harder the other piston drives up. even if the horsepower flat lines the torque will climb with higher compression ratio also.(quoted from post at 07:17:14 07/31/09)
As a general rule of thumb, you gain 4% for every point you raise the CR --up until the pumping looses overcome any gains.
HERES A FORMULA FOR YOU . GET BACK WITH ME WHEN YOU FIGURE OUT WHAT ITS TELLING YOU. E=1-(1/RK-1)(quoted from post at 12:54:58 07/31/09) well i hang out at automotive speed shops. nascar shops actually hook a electric motor to a engine and turn it all through the rpm ranges to see how much horsepower is robbed. naturally aspirated prostock engines run at 16.1 round track engines around 14to 15.1 . I guess youre rebuttal will be that high compression works better in high rpms and not in the low rpms of tractor pulling . the electric motor test proves different though. you can believe everything you test and only half of everything you read.
the formula will show that if you have a 8 to 1 original compression ratio and you increase it to 16 to 1 it will be a 18.6 percent increase now it can be more than that if you change the cam. 8 to 1 up to 12.1 is a 11.5 percent inrease and there again cam profile can help the percentage again . everything in our universe has a scientific equation . Its up to the individual whither they find them and use them or not. no matter what type of chat board they choose to lurk around.(quoted from post at 14:22:32 07/31/09) The mechanical compression ratio maybe 14,15 or 16 to 1 but...................Those are extreme rpm engines with very long valve duration.
Cylinder pressures are no higher than an 9 to 1 engine cammed with very short duration.
Teachers know equations there is no rpm in the equation E stands for otto cycle and k is the coefficient of adiaptic expansion of air.(quoted from post at 04:41:23 08/01/09)
ML , you are debating with the "teacher" when it comes to this topic, i know one of these two gentelmen .
Trust me when i say this !
3 ways of making horsepower relatively cheap is stroke bore and compression . no replacement for displacement.(quoted from post at 16:08:20 08/02/09) thanks agian you guys, i'm trying to decide what to do to get more power out of a stock puller. At this point it does real well but everyone else seems to be adding to their power so i would like to know what step to take next? Do you think a stroker is the answer?
MCQUIOD youve changed youre login.(quoted from post at 19:28:46 08/02/09)
LMBky , you have come to the right place !
Mr Plankey will guide you. His vast array of sound bites will lead you in the right direction.
