Don Eldreth
I can see the benefits in converting from a standard ignition system to an electronic system, would it also be advisable to change the distributor at the same time.
I really don't understand why people convert to electronic ignition though.
Tyler
(quoted from post at 20:14:22 10/31/10) I can see the benefits in converting from a standard ignition system to an electronic system, would it also be advisable to change the distributor at the same time.
E: complaints about removing/replacing front mount distributors. I bet a cup of coffee that the[i:aef8c4b316] majority of owners[/i:aef8c4b316] are much more capable of remove/replace the front mount successfully than side mount. Why? Because the front mt will only install ONE way, whereas the side mount will install into 11 positions plus a +/- variable adjustment, resulting in a virtual infinite variety of installation positions. The experienced can handle either with ease, but I am speaking about the [i:aef8c4b316]majority of owners[/i:aef8c4b316].(quoted from post at 07:19:47 11/01/10) If you have any problems with the distributor or anything else it is best to make those repairs first before converting to EI. I have a 1949 front mount that I have converted to EI two years ago and consider it money well spent. I have owned this tractor for 22 years and my father had it for 25+ years before me. In all those years I have been the only one to work on it. I converted it to 12 volts when I rebuilt the engine for better head lights and to be able to use 12 volt equipment. My main reason for converting to EI was because of the difficulty in finding good front mount points and I also dislike getting down on my knees and fighting to get those two bolts out to remove the distributor. I am also an EE but it does not take an EE to install and set points or install EI. In two years (around 100 hours operation time) I have not had to mess with the distributor at all and my tractor still runs great. I have a side mount 1950 8N that is 12 volts but still has points. I do not plan on converting it to EI unless finding good points also becomes a problem.
(quoted from post at 08:24:18 11/01/10) RE: complaints about removing/replacing front mount distributors. I bet a cup of coffee that the[i:2151476886] majority of owners[/i:2151476886] are much more capable of remove/replace the front mount successfully than side mount. Why? Because the front mt will only install ONE way, whereas the side mount will install into 11 positions plus a +/- variable adjustment, resulting in a virtual infinite variety of installation positions. The experienced can handle either with ease, but I am speaking about the [i:2151476886]majority of owners[/i:2151476886].
hat he said.(quoted from post at 14:33:36 11/01/10)(quoted from post at 08:24:18 11/01/10) RE: complaints about removing/replacing front mount distributors. I bet a cup of coffee that the[i:f0be86fd6c] majority of owners[/i:f0be86fd6c] are much more capable of remove/replace the front mount successfully than side mount. Why? Because the front mt will only install ONE way, whereas the side mount will install into 11 positions plus a +/- variable adjustment, resulting in a virtual infinite variety of installation positions. The experienced can handle either with ease, but I am speaking about the [i:f0be86fd6c]majority of owners[/i:f0be86fd6c].
That is undoubtedly true. But there is that subset of inexperienced owners that bust one of the ears off the front distributor by installing it 180* out and cranking down on the bolts :roll: And of course unlike the front distributor the points on the side distributor are easily chaingeg in situ. Aside from a rebuild I can't think of any good reason to ever want to remove it.
TOH
ee Willie Wonkers, Hobo...don't ya think some might oughta bee skeered? After all there have been people on these boards for years telling other people how bad, how great the loss in spark will be if they have the dreaded reverse polarity spark (positive instead of negative). I mean, how in the world will them little ol 'lectrons ever be able to jump from that cold side electrode onto that hotter center electrode??? How oh how? You do know that a Pertronix EI conversion on a front mount yields a positive polarity spark don't you? No matter if 12v neg gnd or 6v positive ground,...still a Positive spark polarity. :idea:(quoted from post at 19:40:29 11/01/10) Allot of what I was think'n has been posted... The whole issue FM are SM actually boils down to only 1 in 10K know how to work on a dist,,, the rest have no ID how to tell if their chit is worn out... The hole EI/points deal is based on experience form folks that don't know to begin with... Folks either don't know don't wanna know so they are skeered,,, those that have successfully got pass their fears are happy campers and would not go back to standard ignition,,, wonder why....
Its a fact some folks have the money and enjoy spending it on their tractor car are what ever,,, they don't need excuses... Just the skeered need to make'em up....
specially that "what ever" part.(quoted from post at 22:54:01 11/01/10) [i:d3b11a0926]"Its a fact some folks have the money and enjoy spending it on their tractor car are what ever"[/i:d3b11a0926]
Hear, hear.
