Scottvannatta
I have a '55 850 and there is coolant leaking at the top center of where the engine and transmission meet. The engine did freeze one winter and freeze plugs popped out directly above this leak (forward of the battery holder), and on the left side as sitting in the seat. Both of those were replaced but the leak remained. I thought the block had a crack, but when I tore into the area (removed the battery holder and other items to get a clear view), the water is coming up from an area I call a "divot" right at the top where the engine and tranny meet (below the freeze plug). Instead of trying to break the tractor in half and replace the seal, I am thinking about cleaning this area up to bare metal and filling this "divot" which is about 1.5 inches wide, about 3/4 inches front to back, and about 1/2 inch deep (why I call it a divot) with JB Weld to see if it will keep the coolant from coming out. Then I thought I would put some coolant sealer in the radiator to see if it can help stop the leak.
Has anyone tried anything like this before and did it work? I just don't have the resources to break her in half.
Thanks!
Scott V.
Thanks!
Scott V.
