copper head gasket TO 30
David Hogman
Hey Guys, my new fel-pro head gasket failed.(Water in oil) Where can I purchase a copper head gasket? Also, when re- torquing head bolts after warm up, don't you have to remove rocker assembly again to access head bolts, then readjust valve lash? My socket would not clear the head for the side nuts, so used an end wrench and guessed at torque setting. Could this be why it didn't seal.? Thanks to all.
I don't know if anyone is making them but you can get one custom made for around 100.00 to 125.00.
Search Google for custom made copper head gaskets.
They will need your old one.
Your problem might be a warped head.
Did you torque bolts from the center out and retorque after the engine warmed up?
Sorry. I missed that reading your post.
I never did one on that engine but if thats what you have to do to retorque them then I would do it.
Try some copper seal on the next gasket.
there is a formula I will try to remember for using "crows feet" openended wrenched on a torque wrence to torque those screwy bolts.
I do not that the offset of the crowsfeet (in inches) is taken into the formula. There for the extra 1" or so of length will actually reduce the setting on the torque wrench as you have created more leverage. Example only: if you are shooting for 75 ft/lbs for the final torque....your torque wrench will need to be set at around 71 ft/lbs. when the crows foot is used. I will see if I can figure the actual equation out and get back with you.
Torque wrench reading times torque wrench length divided by total length (torque wrench length plus extension) equals actual torque applied
The head was rebuilt at machine shop. Re-torqued the head bolts after warm up, but had no thermostat fitted so it might not have gotten warm enough as nuts didn't move much more. Used spray copper sealant, torqued by the manual sequence. Thought I would try a better gasket next time and warm up motor longer before torquing again. Don't know what else to do, everything seemed okay the first time.
I suspect you tired to go Hi-Teck on a lo-tech engine. I used the simple gasket through this web site on my '20 with "Cup Grease" or perhaps better known as wheel bearing grease as explained by John(UK). It seems this allows the gasket to flow as needed and when the grease dries trying to take the gasket off is fun when it tears in 1/2. Seems some idjit busted a head stud...
and had to go back into the engine...
I had exactly the same problem after the head was rebuld some gasket cement sorted it.
When I re-torqued I removed the rocker and re-did the valve clearances
