corn harvesting
Bob seND
Does anyone have experience combining corn with
a straight head as opposed to a corn head? I'm contemplating this with my 6601.
Wont work.btdt.what little that makes into into the head(the reel will push it over),will hvee too much trash to separate out.
Yes no and maybe. Have seen it done. Do you have sunflower trays for the front? got to have something to stop the stalks falling out the front have seen it done with the reel still in place lifted fairly high or removed all together. Not as good as a corn front and you will get some losses and will have to put all that plant through the combine so ground speed will be slower
We had some pitiful corn one year, the ears were so small that they would go into the snapping rolls and get crushed and fall out the bottom. We ran the grain head a few inches below the ears. I don't remember there being too much loss, but it was better than crushing 90% of the ears. Had to slow down a little, but not as much as I expected.
I've heard of it done, in poor/ down corn that didn't yield well anyhow. On good standing corn, it will be your worst nightmare by the time you are done, very slow with all the plant going through the combine, and lots of loss from the reel pushing the plant over. If you had lots of wind stripping the leaves off the plant & leaning them one way, you'd have a chance of combining one way into the lean....
--->Paul
Do you have a corn picker? Or some people with fast hands and a bank board wagon? If you ran the corn through a picker, then hand shoveled it into the auger on the combine (preferrably with the reel and sickle belts removed) or used an elevator, you could do it. But I don't think the cylinder on the combine would enjoy those heavy wet corn stalks being in there. Sometimes a few poke berry weeds will squeal the belt on my combine. I am sure a corn stalk would give my combine a heart attack.
I have shelled earn corn with the combine, though. just like I described... ran it through the header by feeding it in on both sides of the auger so the auger would even up the flow into the feederhouse. worked good, except I had a huge pile of husk and corn cobs that I needed to dispose of.
It will work for a while buts its very hard on the sickle & next will be way too much trash for the separator to handle.
