(quoted from post at 14:38:55 01/29/17) Thanks, guys. I got the corrosion off and was able to remove the nut. Now, that nut is but a thin shell of its original self! I will replace at least the nut. Would you advise that I replace the entire clamp? If so, how is that done? Or, should I give it a try with a new nut and see if I can get a tight fit?
(quoted from post at 20:20:21 01/29/17) If you don't want it to corrode up again, seal the area around the post and case. Acid leaks up around the post and corrodes the terminal. I seal all my batteries when I buy them and never have this problem. Be sure to clean and dry the battery before sealing.
(quoted from post at 22:20:21 01/29/17) If you don't want it to corrode up again, seal the area around the post and case. Acid leaks up around the post and corrodes the terminal. I seal all my batteries when I buy them and never have this problem. Be sure to clean and dry the battery before sealing.
(quoted from post at 07:16:25 01/30/17)(quoted from post at 22:20:21 01/29/17) If you don't want it to corrode up again, seal the area around the post and case. Acid leaks up around the post and corrodes the terminal. I seal all my batteries when I buy them and never have this problem. Be sure to clean and dry the battery before sealing.
How do I seal the battery? Is that what happens when you use the battery terminal protection spray?
(quoted from post at 08:41:27 01/30/17) If you seal battery terminals with battery terminal protector they will look like this and they don't collect dust and dirt like grease.
Here's a photo of what it looks like and if this was mine I would have gave it one more coat.
