covering haybine outside
PaBob
I have a 477 NH haybine that I can not get in my pole barn. My question is should I use a blue tarp, or nothing I was told by old timer that tarping equipment draws moisture to the piece you are tring to protect? thanks;
I cover critial parts with a heavy canvas (not plastic nor the whole thing) and give the sickle a good dose of used motor oil. Remove any built up hay or dirt first. It still hard on the paint but haven't had any mechnical issues going on 5 years
My NH460 never has seen a bard or shed since I have owned it. I grease every thing up real good and oil the heck out of the chains and let it sit. Then in the spring grease it up good and oil the chain up real good and go. NO TARPS not cover of any kind and have been doing it that way for 10 plus years and it keeps on keeping on. Way back when few machines ever saw a shed or barn and they are still around
Hobby farm
I tarped a baler once, then I noticed that the wind blowing the tarp caused it to wear paint off. Now I use a piece of rubber roof material to cover only the bale chamber. it doesn't drape down far so it can't hold moisture in and it takes a very strong wind to move it.
The only cover I use on my 469 is a 9' peice of plywood cut to fit over the rolls between the reel and the body. It keeps the sun and snow off the rubber rolls.
I do what Showcrop does ( use a strip of rubber roofing about 3' wide and 8' long ) for my balers chambers and knotters but I also cover the whole thing with a heavy duty tarp from any wally world to keep snow out of the chamber and the twine compartments. But to answer the question - No , I don't cover my moco. But mine is a 990 IH so as such it doesn't have bonded rubber rolls like yours does. I'd cover the bonded rubber at least to keep the sun off if I were you.
