cow not eating her grain
c.w n.y
my jersy cow that freshened may 1 has lost intrest in eating her grain at milking time, she will only take a few licks and then just stand their. it has been hot the last few days would that put her off eating or is it most likely ketosis she appears normal other wise chewing her cud i put her in a field of sweet clover and she chomped that preety good, then i moved her to a nice leafy timothy grass field where she went to work on it. should i be taking any other actions now.
c.w n.y
I have a Jersey herd and use rationed grazing. Sometimes the cows aren't interested in much grain if they have been able to fill up on clover. I would want to check her temperature and milk to rule out an infection, and check her belly and manure output to rule out bloat or a DA. If she is milking well, and otherwise seems OK, you may want to give her some straw or dry hay, as spring pasture can be low in fiber and lead to rumen acidosis, which could also put her off grain.
If her breath stinks like garlic she has cotosis 2 cups of white or brown sugar a day for 2 weeks will fix. they will go off grain if they have cotosis. At least mine did. If she stops milking I would think it might also be a calcium dificeintcy watch for signs of milk fever. Jersey seems to prone to that.
IF she's milking OK I wouldn't worry too much. Probably just full....
If milk is slipping, could be a lot of things.
Milk fever, grass tetany, a fever brought on by any number of things...
Be worthwhile to get a vet if she's actually sick.
Rod
thanks for the replies, she seems healthy otherwise ill keep a close eye on her and if she slips any ill have to call in the vet.
