cracked cast rear wheel
Lorily
We are just about finished restoring our JD 630 and my husband was tightening the bolts on the rear cast wheel and it cracked. He is not sure what he may have done wrong. He did have to heat it up a long time ago to get it off, because it was rusted on. He thought maybe that could be a reason. He also said he tightened the bolts in the outside of the wheel first, then the inside bolts. He did not have any torque specs, so he just tightened them down and the cast rear wheel cracked. Does anyone know the reason this happened. We are afraid to put the other one on without knowing the reason this happened. We don't want to ruin the other one. My husband said the part number is F1500R. Any input would be much appreciated.
F 1500 R is used on the 50, 60, and 70 I believe. The only thing that is different is the sleve to match the axel size, so, getting a replacement part should not be a problem. The part should be cheaper than the transportation.
--Walt--
When I saw the title heading, my first question was going to be how much heat was used. You have already answered this and that is why it busted. I would say there is a good chance that the other one will bust too.
I always jack the back end up, take the original bolt out and put used bolts in and hit it was a sledge hammer. I also use a 3/4 impact wrench to help push the wedge out. Some people do not suggest this, but I am yet to break a bolt, strip the casting threads, or break the whole casting.
Good luck.
The three inside bolts mush be tinghten frist as the in side hub has a shoulder to set in to the F1500R cash center i have the F1500 hubs on hand if i am not to far from you Kent eastern SD
