CRANKSHAFT PULLEY
Check the archives and if you look enough to will find pictures of one Keith made to pull those pulleys. I uses a hyd jack and some other stuff to do the job. Or maybe you will get lucky and he will post it again for you
just got done pulling the crank pully on my sc. i borrowed a split bearing tool and a big puller from a good friend. it took a big pipe on a half inch breaker bar. thought something was going to break. it would not budge until we rapped on the end of the puller with a big hammer. then it moved a hair. we had to repeat this till it was almost off before it startedto move easily.
Old called me and informed me you were having problems getting the crankshaft pulley off. When I started on Shawn's SC I read all kinds of horror stories on removing the lower pulley, so I set down and designed a hydraulic one to remove that stubborn thing. If ya need anymore info just email me.
Keith & Shawn(Gold Medal Winner)
Thanks "abuckshot" for posting the info where I put it on the last time.
LOL oh by the way I didn't hang up on you but my phone went AWOL on me. Guess it is getting pretty bad when I take the time to call you so you can make sure the guy gets the info he needs LOL
