Cub Cadet Kohler Engine
I own a 16 HP Cub Cadet that I believe was manufactured around 1982. It has a 16HP Kohler K-341 engine. The engine is getting pretty tired, no more power and burning quite a bit of oil. I would like to order a complete new Kohler engine for it but I'm afraid of what exactly to order. There are many applications for this engine and I want to make sure I get the right one that will fit right in without hassle or modifications.
The serial number on the current (and tired) engine is: 8331495 and the serial number on the Cub Cadet is: 2050670U622974.
Would order directly from a Kohler dealer be advisable or should I go to a Cub Cadet dealer?
Any help on getting a new engine would be appreciated.
Thanks,
Pierre
I don't think a new engine is available,those old K series engines are tough,rebuild your old one,but do it right'bore the block,turn crank,new piston assy.,new rod,do the valves.Do not use old rod over,even if crank does not need turning.Scott
I did my 14 hp for about $250.00 last year piece of cake and yes do get a new rod that ussually the first thing to fail.
I've heard you can buy them completely rebuilt, but when I pressed for details no one seems to know where you can get them.
You can get a replacement engine from these guys:
http://search.stores.ebay.com/SmallEngineWarehouse_cub-cadet_W0QQfciZ1QQfclZ3QQfsnZSmallEngineWarehouseQQfsooZ1QQfsopZ1QQsaselZ313941QQsofpZ0
Several people have had good luck with the Honda 20 hp engines.
Here is a detailed thread on how to do it:
http://farmallcub.com/phpBB2/viewtopic.php?f=2&t=14796
Or you can buy a rebuild kit. The one I got off Ebay was OK - except one crank seal wouldn't fit. Even with having to order a second seal it was about 1/3 the cost of buying an OEM kit.
http://cgi.ebay.com/Master-ENGINE-REBUILD-KIT-W-Valves-FOR-KOHLER-K341-16HP_W0QQitemZ130289369730QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item130289369730&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A7%7C39%3A1%7C240%3A1318
