My cub gas line is a 5/16 tube that screws into the carb with a fitting that leaks and has a ferrule on it. Was the original like that with a ferrule? Or was it a 45 degree double flare or a single flare? I go a new kit for the carb and do not want to screw it up when I connect it up.
The 5/16 end then has a 1/4 tube up to the gas tank with a rubber hose making the connections to the filter and gas valve. I could jb weld the tube nut to eliminate any leakage if need be.
