Cub issues first one UPDATE
grandpa Love
Pouring rain off and on here. Left over from hurricane. Been in barn tinkering. Battery charged all night. Tractor fired right up, but coil got really hot in a couple minutes and tractor died. Wouldn't re start. Swapped coils and it fired right up. squirted a big shot of transmission fluid in the carb, (best done outside),ran smoother after it blew all out, not a bad running little tractor. New ,minor issue, got some of the transmission fluid and air bubbling up around 2 spark plugs. They are tight, afraid to tighten them more..... Suggestions?
New plugs and make sure where they seat is rust free.
Perhaps anti seize on threads may act like a gasket,
I suspect many spark plugs would do that if they got fluid around their seating areas. I would not get to wound up about it. That little bit of compression you are loosing is like a gnat on an elephants butt. Would be interesting to see if the newer tapered seat plugs leak like that.
Very common for plugs to leak around the gasket. As long as it has the right length thread on the plugs, the gasket is in place, the seat is clean, the threads let the plug go down all the way and put some crush on the gasket, it won't hurt anything. If the plugs are stopping before they compress the gasket you can get a special spark plug thread chaser to clean them up. Be sure to put grease on the chaser to catch metal chips and debris.
Wonder why the coil got hot? Is this one 12v? If so be sure you have the right coil or coil/resistor combination.
Could have been a bad coil, and as long as it's not getting hot now should be OK.
After checking I realized I had an old 6 volt coil on it. Swapped it for a 12 volt, no resistor needed, coil and it's much happier.
