My cub ran all summer but will not start with this recent cold snap. It trys to start if I choke it first and then open it a little but seems to kick back a occasionally which sounds to me like it is advanced too far. I am hand cranking it with no battery just the magneto.
I get good gas flow and the carb jet is clean. I installed the magneto this summer according to static timing instructions and it seemed to start and run ok.
Can I just loosened the mag hold down bolt and rotate the mag just a bit to retard the timing? Should I rotate it CCW or CC to retard it viewed from the rear of the tractor?
I plan to keep it running on the magneto and no battery if I can.
