grandpa Love
Got a magneto coming in the mail today for the slightly burnt cub. Compression stroke is when both valves are up? Or down? Looking in #1 plug hole. Thanks.
(quoted from post at 16:04:54 01/23/21) valves will be closed as said, BUT if you rock the crank back and forth and both the valves open and close then you are not on compression stroke. these valves are not fully closed, neither will you have any rocker clearance. compression stroke the rockers are loose, and do not move when rocking the crank.
