Cub won't run without choke
Ken C.
My '51 Cub ran fine for years, & suddenly started running rough, & needed choking to keep running. I installed new gaskets, set the float level to 1 13/32, cleaned carb with no results. Lastly I tried mowing with it with the choke partly pulled, ran fine for a while, then gradually ran so rough it had no power. Seems so much like a gas problem, with a very simple carb. I need some help.
Thanks, Ken
Pull the carb drain plug and make sure he flow of gas will fill a pint jar in less then 3 minutes 2 is even better and yes catch the gas to look for dirt/water.
If you have that good chance you missed something in the carb. While they are simple it doesn't take much to stop a carb main passage up
the 51 should have a IH carb and they are notorious about the main jet getting trash in it this jet is a brass plug that is mounted on the side of the carburetor. you can take a single solid copper telephone wire and rod that jet out
This post was edited by tn terry t on 07/13/2021 at 07:08 pm.
No real answers but just keep in mind if it runs better with choke on it means one of two things.
1st too much air getting in.
2nd not enough fuel getting in.
Those I know have been addressed by the others but thought it would be good to put it in to simple terms.
you need to verify that is has a good flow of gas going into the carb. if that is good then the carb has to be soaked n carb cleaner for few
hrs. you will not clean a carb just by swishing it around in gas or whatever, well maybe the outside as thats what i do to get all the junk
and dirt off as you dont need that contaminating the carb gunk. then a cool water rinse then you blow out passages with air and watch to
make sure they are open.
I have this cheap carb on several cubs.
Well worth the money. Every one we
have bought had to have this hole
drilled out. Looks like a bit broke in
the CNC machine and no one caught it.
Lol. Try it,it will eliminate a carb
issue.....
Had a couple cub carbs that were
warped and not rebuild-able. Air was
getting in around the top and bottom.
Nothing helped, except a new carb.
I often wonder if I drilled the hole out as big as I should have on the carb I have. I don't think it is reaching the HP it should but don't know for sure. Would be nice if I knew the drill bit size you used
First, thanks for all your help & concern. After having the carb off 4 times (doing a quick & dirty cleaning, re-adjusting the float, installing new gaskets & more) I finally took it apart once more. I have a small Magnasonic ultrasonic cleaner used for dentures & jewelry. Each halve of the carb fit in
one @ a time. I filled it up to the top with Gunk carb cleaner with one half carb in & ran it for a total of 30 minutes for each half. The solution got quite hot during the process, which I believe aided in the cleaning. Blew out the halves, re-assembled, & mounted on the tractor. Started it up & IT
RAN ABSOLUTELY PERFECT!!!!! I hope this helps others, seems that many are having the starving for gas problem.
Ken C.
