cubic in. formula
Pie R squared is the formula for the area of a circle. Area times stroke times number of cylinders will give you cubic inches.
Radius (1/2 of bore) X radius X pie (3.14) X stroke X number of cylinders.
(quoted from post at 05:38:18 10/17/11) Stroke x bore x number of cylinders x 3.14= cubic "
That is the formula I have always used, and it has never failed to agree with an engine of already known c.i.d.
(quoted from post at 06:41:06 10/17/11)
If You INSIST ON USING 3.14 You should finish the equation like this 3.14/4 cause when you do that it equals .7854 geometry it is what it is
(quoted from post at 07:53:28 10/17/11)
ominee built a 403stroker cubic inch engine bore is 4.625 stroke is 6what inches 4.6625*6*3.14 is 348 4.625*4.625*6*4*.7854 is 403
(quoted from post at 22:27:34 10/16/11) done forgot how to do it anybody know formula on hand thanks in advance
Call me a stickler, but I have always used pie = 3.141592, more decimal places you carry it out, the more accurate your result is.
(quoted from post at 14:58:07 10/18/11)
Ok you then have to use north pullers formula radius^2 x stroke times number of cylindersx pie . If you use only bore or radius once and don't square it with either 3.141592 or .7854 it doesnt come out correct
(quoted from post at 11:53:46 10/19/11)
:roll: I know that. Pie times the radius squared times the length of the stroke times the number of cylinders is the standard formula I learned in school a long time ago. It is also where I developed the habit of carrying pie out to six decimal places. I majored in computer sci and minored in math, business admin and history. :lol:
