cutting angle iron
MF294-4
Why does my chop saw quit cutting after I cut through the thin part? I realize that I have more surface area to cut but the sparks change and no amount of pressure can make it cut. Of course it will cut the rest of the way through if I turn the angle over but I would think that would not be necessary. This is 3x3x1/4
I always try to cut with the point up, too. Sometimes you can't, because the vice won't hold it tight or square enough. When you start cutting the flat leg of the angle, the steel will get so hot that the molten metal will plug the blade up. If you take a piece of flat strap and hold it against the blade, just before the blade enters the cut, it will clean the metal out of the blade and it will cut again. Only do this on the back side of the blade where it is rotating away from you, or the blade will grab the metal and stick it through your hand. Also wear welding gloves, because the metal will get hot, and they will also protect your hand from the blade. Use a long piece of metal, so that your hand is away from the blade.
What they said below.
Assuming it's not a depth of cut issue because the abrasive disk is too worn, the usual reason is that the metal work-hardens from the heat as it's cut.
If you MUST cut it on the flat for some reason, don't baby it, lean on it as much as the saw will take without slowing down or popping a breaker. If you don't use enough pressure and the wheel spins in the cut without cutting, you're just building up heat. As long as the blade is making progress, you're less likely to workharden the piece.
its hardening the metal because of to slow cutting, more pressure down or change angle of attack. After all all chop saw is doing is burning it into. If you do much cutting at all a bandsaw is the way to go period in my eyes. I went thru bunch of those chop saws and blades well thats another story.
got band saw and what difference. blades last me three years usually if I DON'T do something stupid like not make sure piece is clamp tight first before cutting
you want the least amount of material contacting your chopsaw blade at all times for more effecient cutting. Cut through the "thin part" then stand it up again (1/4 turn) so you are cutting through the other "thin part".
I've cut a lot of angle making carwash machines, like 2' conveyor legs, usually 160 in an order. On the bandsaw I have the point up. The 16" cutoff base was point down for angle. Cutting fast is better or the blade edge will load up. 3x4x1/4 angle took about 4 seconds with a 5HP motor. If it does load up amd not cut, hit the edge with a piece of scrap while it's running so the ding will open it to new grit. Assuming you'll have your shield/goggles on. HTH
Also might consider switching to a thinner disk, if you haven"t already. 3/32" thick wheels are available in various grits...doesn"t sound like much difference from the more common 1/8" wheels, except you"re cutting 1/4 less width. Made a diff for our chop saw. Follows same reasoning as others have mentioned - try to take off as little as possible.
BTW, you might also consider 1/16" thick slicer blades in a 4-1/2" angle grinder. You can often freehand a pretty square cut following a line, and these disks cut like beegeezers. We use ones from Metabo, get "em at Fastenal. Just picked up another 5 or 6 the other day. They don"t take twisting & sideloading so be careful and wear good eye protection in case one comes apart.
Well Travis has it partly right but it needs cleaned not sharpen.
Just take the blade out and reverse the direction of cutting as the blade pores are loaded up and closed so the blade skips on the surface creating heat thus causing more blade loading.
If you had a 5hp t0 10hp motor, then you could load the cut with pressure and keep the blade clean. Hard to do that with a 2hp motor.
Another handy item on a chop saw is a chain hold down on the piece to be cut. Doesn't take much too make it DIY project.
T_Bone
As Tim (The tool man) Taylor always says, “More Power!” When it comes to chop saws, I don't think you can have too much power!
Here is a simple DIY project I did about 25-years ago. 7 1/2-HP. Can't ever remember it stalling. It will cut 4-inch round stock in just a few seconds.
Well, I haven't seen anyone describe this so, I will mention it.....the faster a grinding wheel runs, the harder it acts...if the wheel doesn't break down (to present a new cutting surface)...it just loads up and creates friction and does no cutting. So, if you had a way of slowing the wheel down, it would then break down (as it is designed to)and would fracture off the dull grit and present a new cutting surface. Now, if curosity gets the best of you, take a wheel that is worn down and try it....one that is doing it's thing will break down as you're using it and throw grit all over you....reason? The wheel is lesser in diameter than a new one, therefore running at a lower surface feet per minute speed.....and acting softer. Now, how to get that wheel that is loaded up to cutting again? To me, I'd just let off of the trigger and let the wheel slow down while still bearing down on the cut...remember, slower is softer? And if the metal is so hot it just wipes (purple), pour a little water on it to cool it some and then do as above. You might also try a quality wheel to begin with and find better results. I'm tired, I quit, schools out.....ohfred
that is the trouble with these saws,they're only good for thin stuff , best way is to put angle iron and tubing under a angle , dont cut on the flat side,it'll just heat up and stop cutting.The harder you push down the worse it gets. When cutting round material, roll it slowly around as you cut, and it will cut trough like butter. If cutting heavy stuff like drillstem get the garden hose to cool it down with water as you cut,I found that works best in these situations,and will not harden the material.
Cutting with a chop saw is like cutting with a metal band saw. You have to have as much contact as possible between the blade and the metal being cut.
On the band saw this keeps more teeth in contact with the work and prevents the blade from locking up.
Everyone wants to cut metal with the thinnest part first because it goes faster. This is wrong.
Cut your angle iron with the corner facing upward and the two legs facing down. This way you saw will be cutting the same amount of metal thru the entire cut.
For flat bar steel cut with it laying down, the widest edge facing up. You'll have more teeth in contact with the work surface on the band saw.
Many people try to push chop saws way beyond their limit. The thinner the cutting wheel the better.
(quoted from post at 05:33:25 12/27/08) For flat bar steel cut with it laying down, the widest edge facing up. You'll have more teeth in contact with the work surface on the band saw.
Hi John B. I was of the same opinion as you about cutting with a band saw, until I bought an Ellis 1800 band saw and actually read the instructions, (happens very seldom) :oops: . Ellis says to always cut with the least amount of teeth in contact with the object being cut. As in flatbar vertical or at least at an angle. I was shocked :shock: ! So I asked the kid you runs the large HEM saw at the local steel supply, he said that is how he was taught too! In fact they have a jig to lay all their flat bar in the saw at an angle.
