cycling 3pth
550Doug
Location
Southern Ontario
How do I cure a 3pth that cannot stay steady? It continually cycles by moving up a couple of inches, then drops back down the 2 inches and continues to do this no matter what height the arms are at. I've removed the servo valve and checked nothing is sticky, but I suspect an internal leak somewhere. Any ideas?
Thanks
Usually this is caused by leakdown of the lift cylinder. The oring or seal gets worn, oil leaks by it, and the arms drop. The control valve senses the drop and sends more oil to restore it to the set position, then the above repeats. Since it is dropping and then resetting itself, this is a good indication that the pump and control valve are OK. Good news is the cylinder oring or seal is usually not expensive (I have done International, Deere, and Ford). The bad news is it is usually not easy to get to.
Doug: Never did the Cockshutt but it is very similar to an Oliver 550 I have done those. What is this Oil pullcylinder. I like talking those better than the Oliver or Cockshutt. J.
Doug, curious as to what you find. My 540 does that, but my 550 does not. I would think it is a leaking oring on the cylinder piston (hopefully)or a leaking control valve.
Enjoy your 540. Great little tractor. I have had mine 14 years.
Regards
Neil
had the same problem on a Farmall 806. replaced the hydraulic lift cylinder (pitted rust), piston and o ring. got another one to fix...
that kind of info, we needed to know when you asked the question.
however i agree with some of the others.. there is a leak in the circuit, and the lift is dropping.. when it drops enough that the internal linkage 'senses' the drop, then it regenerates the circuit and the lif comes back up.
prime places to look are at the lift cyl itself and any valving or lines / gasket / oring connections between those parts.
soundguy
