camshaft76
Hello all.. I have an 8N that I bought recently. It sat for a few years from what I'm told.. but I replaced the plugs, wires, cap, rotor, points,condenser, filters head gasket, carburetor, ignition switch, pushbutton, and left front valve cap.. had to put a little oil down in the cylinders but all 4 are hitting right at 100-105 lbs compression.. having said allat.. it spits back through the carburetor when I put it under much of a load.. and for some reason it almost refuses to go in reverse without dying.. flat ground is okay. And I can pull dirt with a box blade if it's not to much.. but any grade elevation and it pops badly.. if changed the governor, and I have fire to all the plugs.. but I can pull #1 and #4 wires off the cap, and it doesn't change the rpms at all... 2 and 3 wires will shut it down if I pull either of those... so my problem has gone above my pay grade.. any thoughts or advise would be greatly appreciated...
