Cylinder Ridge
I am replacing the cracked head on a WD45. There is a significant ridge in the cylinders. If I just put the new head on, will having a rebuilt head cause any issues with the untouched lower 1/2 of the motor?
The tractor is not a trailer queen. But it will only see light use. Probably in the 8-15 hours per year. It will pull a loaded hay wagon back to the barn on occasion. It has a trip bucket loader and might move a little snow. Otherwise it pretty much acts as a motorized wheel barrow.
Do I need to tear into the lower 1/2 or can I leave well worn but well enough alone?
The weakness of those engines was only three main bearings and not much oil pressure. I would assume with that much obvious wear on the sleeves the bearings would be likewise. Easy for me to say from a distance now is the opportune time.
But I don't think a head change will affect much else.
I have heard this argued a thousand times and you will get a lot of different answers. Personally if I were doing it for a customer I would either not do it or make them sign a release that I wasn't responsable for any other problems. Every engine that I have tried this on used an excessive amount of oil after a valve job or replacing the head. You said that you had a cracked head. If anti-freeze got in the crankcase, I would also be very concerned about the bearings being damaged, they don't like anti-freeze.On the other hand, no more than you are using it, I don't see how you can justify the cost of a major rebuild. A quart of oil every now and then is cheaper than an overhaul.If it had decent oil pressure and didn't knock, I would probably give it a try.
Paul from MN,
Be careful of valve jobs and quick fixes. I once worked in a plant where we had a lot of machines that ran constantly. When an engine would get 'tired', someone would be assigned to give it a valve job. Within a month or two that engine would always start drinking oil and within a little while the bottom end would go.
A tired engine is tired all over. Bringing back up compression puts strain on the parts that are not used to such a strain. Fixing a head is only a temporary fix. In this case temporary might be a long time, if you are careful.
Charlie
You may get by just fine or you may find you blow the rings out the bottom. I have seen it go both ways and my self I prefer to do both the top and bottom or leave both alone. That ridge sort of shows you how much wear you have on that engine and if it is enough to catch your finger nail on it is a good bit of wear. So if you do not do the lower part it may start to use some oil you never know for sure and it is a gamble not to do the lower end but then it also cost a good bit for a sleeve kit
I had an old Chevelle (283) that burned a valve. I reworked the heads. I could then kill mosquitoes for miles after that. Pulled the engine and did it all. You could do a short overhaul, in frame, if it can be done.
I don't see where a head-change is going to change anything with the rest of the engine. It is what it is. I've heard the old argument many times that a good tight head will just raise the compression and put more of a load on the bottom end.
Only scenario I can think off where it would cause "new" problems - would be if the old head had really leaky valves and the engine subsequently skipped and had low power. You then put on a tight head, all the cylinders now fire and you've got more power, and now burn more oil.
I've done a lot of valve jobs on old beat engines - and always wound up with someting a little better, not worse.
Usually an engine with a lot of ring groove has rings that are wore out.So instead of being whatever a new ring thickness is,they are thinner.So that means the end gaps are bigger.Which can mean they dont have as much tension besides being worn out.So that means you have less compression and oil can go by them easier.Depending on what you want to do with it would make the difference.If you are going to work it hard I would put new rings and liners in it.If I was just going to put it in a parade or something fixing the head might work for me.
I would ream the ridge out so the top ring can not hit it. Sure, you haven't changed anything in the bottom end, but as others have said, the ridge is a sign of a very probable worn bottom end. I had a 55 Plymouth flathead 6 as my first car and unknown to me it had ring ridges. With another year's of driving, there was now enough bearing slop to let the piston come up higher than any time before. Yes, the RPMs were up, but not beyond normal driving. 2 pistons smacked their top rings on the ridges and broke the top land of the piston. The rings went over the top and smacked between piston and head. The engine sounded like it was beating itself to death. When I pulled the head, there were shards of rings embedded in the top of the 2 pistons. Most of the pieces had gone out through the exhaust.
So I always ream the ridges even if I am going to bore the block. It makes getting the pistons much easier to get out of the block. A ridge reamer is not an expensive tool. Its cutting power is supplied by your hand turning a wrench.
The other guys are right about the engine needing a full rebuild, but I understand with the current economics, many guys have to do what then can to get by.
BTW: I am the original
Paul in MN
Ridge reaming unles he is going to pull the piston out will not help as a matter of fact it very likely will hurt for 2 reasons. #1 there is no way to get/catch all the shavings and #2 that ridge was put there by the rings and it will not hurt the rings since the rings will just keep adding to it
I agree with the many comments about your engine being worn - but unless I've got a reading-comprehension disorder - you didn't ask if your engine is worn.
You asked . . .
"will having a rebuilt head cause any issues with the untouched lower 1/2 of the motor? "
To that, the answer it NO. The head is not going to make your bottom-end any worse, or any better, then it was before. And, if it was an oil-burner, it might actually improve a little via better valve guides and seals.
Old,
You and I agree on many things, but I'll agree to disagree with you on this one. I can keep the shavings from droppin betwen the piston and cylinder wall by using glazing putty rolled out thin like a good fishing worm and gently put at the top perimeter of the piston. Use your air gun or shop vac to get the 98% of the shavings out and then pull up the glazing putty with a few shavings stuck in it and throw it out. I'll never put an engine back together with noticable ring ridges.
But you do it your way, and I'll do it my way. We may never see a difference, but as I found in that old Plymouth, the ridges can be disasterous. Maybe that engine was one in a million, but it was mine and it suddenly got very sick. As I was a church-mouse-poor college kid at the time, I didn't have money for new bearings and turning the crankshaft. And I needed to get 2 more years out of that car, so it got 2 new Montgomery Wards pistons w/rings, a head and pan gasket and 6 ridges reamed. It ran for many more thousands of miles.
Paul in MN
On one like that I have learned it would not have helped either way because if it is going to go it is going to go so doing it or not would not have hurt or helped
I would put the head back on, torque it to specs, put some 40 wt oil back in, and not look back. With that few hours of operation in a year you will not have a problem. Most tractors in use get that many hours in a couple days. stan
The top and bottom have done the same amount of work. take one bearing off and check the shell wear.If copper colour I would do more than hope.
NUTS!!!! I pretty much knew what you'd all say, but was still hoping for "put it back together, it'll be fine...."
Thanks for taking the time to share your wisdom
You say you had a cracked head. Like someone below, I'd also be concerned about coolant getting into the oil and taking out the bearings.
I was working in the parts department at a Ford dealership when Ford came out with the head gasket recall on the 3.8 V6's. The first repair was strictly a head gasket replacement, after cleaning the head and block surfaces [often with the heads being resurfaced, if there had been any warpage] and a total fluid change...and 9 times out of 10, engines that weren't knocking when they came in with bad head gaskets would begin knocking after the head gasket replacement. These cars then would get a replacement engine, and the bearing damage was caused by coolant getting into the oil...and I'm not talking about a gallon, or even a quart of coolant in the oil.
The other side of the coin is that I recall Pappy and Grand-dad doing a valve job on a private contractor's mail truck with a small block Ford V8. The engine had well over 200,000 miles on it, and Pappy had tried to steer the customer towards a full overhaul. But he was not in a position to pay or anything more than the valve job [this was in the mid-1970's,and the way gas prices had risen, he'd ended up bidding the job WAY too cheap]. So it was agreed that Pappy and Grand-dad would do the valve job, and there was NO WARRANTY on that engine afterwards. Within 30 days [they were running the mail 7 days a week then], that engine was smoking like he was fogging for mosquitoes. The lack of compression leaks on the top side had put more pressure on the piston rings, and since they were already weak, they failed.
Not saying any of this will happen to you...but by rolling the dice, are you prepared, financially AND mentally, if you lose your bet and have to tear it all back down and do it "right" ??It's YOUR tractor, and you have every right to do whatever you want with it. Just be aware of possible consequences. Not EVERY bank robber goes to jail; that's why some folks take the risk. Sometimes someone gets lucky...and in the case of this engine, you may be one of the lucky ones. It's your tractor, your time, and your money.
