I have an early D-10 SN 1126. It is or has been converted to 12 V. It starts and runs like a champ and as far as I can tell it is charging fine since I have started it many times and it hasn't run the battery down but gauge doesn't work. It is currently Positive ground. Looking at the Owners manuel for D-10 SN 3501 and up the wiring diagram shows a 12V battery with the Negative post hooking to solenoid switch and the positive post grounded but the first paragraph says heavy cable from POSITIVE terminal to starter solenoid switch. Which is what ? Am I supposed to be positive ground or negative ground? If it is supposed to be negative how do I change it? I know my wording is a bit disjointed but that is the only way I know to say it. Thanks, Nat
