d-17 allis chalmers tractor
pinball
what kind of oil do you all use in the transmission. calls for ep 80 but local store didn't have any ep oil. thanks
The EP is for extreme pressure. I believe all gear oil or at least good brands are ep rated. I use 80w90 in my dads D17.
EP stands for "extreme pressure" additive, 80 is the viscosity.
Most modern SAE gear oils have the EP additive.
You really need a GL spec to get the proper additive level.
GL-1 is the straight mineral oil, no EP additive. Not what is recommended for your application.
GL-2 through GL-5 each have progressively more EP additive.
Depending on what's inside the transmission determines the additive level. If there are no wet clutches, wet brakes, or yellow metals, go with a higher GL rating.
