DavidKittle
Hi;
I took the battery for charging, and reinstalled it the same it came out with the negative to the ground.
I hit the starter and the engine had speed, but no start. Eventually, it hi t, ran, then quit.
So, I checked the fuel, pulling the line at the carb and had good flow.
I checked the spark as follows: Took off the cap, rotor, dust cap. Turened on the key. I had a weak spark when I separated the points, that was tiny. Should I not have the fat blue spark here? Does this mean anything, or do I need to look elsewhere?
i can"t get over having this problem after just taking the battery out for a charge. Makes me want a charge now!
Thanks
Thanks
