I've been working on my d-19 trying to get it running well and have run into a pile it f problems. I e of the problems I'm having that should be the easiest is with the carb. I took the carb off to clean it the other day and things went off the rails. First thing was the float Axle wasn't there. At least that solves the why of the needle not shutting off. Next I found a bent main needle, and an ugly idle needle. After that I seen a tiny bit of paint in the very top of the carb, there is a pin hole in the top that leaked into the carb. Well I got most of that taken care of minus plugging the pin hole. Now I want to set the float and can't find a setting in the manuals I have for it. Does anyone have the float level setting for a marvel schebler carb for a d-19? Thanks
![cvphoto159567.jpg](https://www.yesterdaystractors.com/cvphotos/cvphoto159567.jpg)
