D15 engine swap help
Dodgeit
Just looking to find out which engines from other tractors or combines will bolt up and which give the best performance.
Is yours series 1 or 2? If Its series 1, motors from b, c, ca, d-10, d-12, d-14, and d15 series 1 will all bolt up, no problem, at all. Series 2 d-15 motor will bolt right up, but there might be some sheet metal, and frame rail issues, maybe radiator and shroud fitting issues, too.
the B-C have smaller 125 cubic inch motors. The slightly larger D10-12 i think have a 138 inch motor. The D15 has a 149 inch i believe. THE smaller motors are more common, but will be much less horsepower and not very usable. If at all possible, i would have the larger motor rebuilt.
(quoted from post at 22:24:16 12/16/11) the B-C have smaller 125 cubic inch motors. The slightly larger D10-12 i think have a 138 inch motor. The D15 has a 149 inch i believe. THE smaller motors are more common, but will be much less horsepower and not very usable. If at all possible, i would have the larger motor rebuilt.
Looking to add more power. Will the Gleaner engines bolt up like they used to in the WDs?
You should already have the best bolt in from this engine family which is the 160. Early D15s might still use the 149 like a D14. If you have the 149 your only options to upgrade is from a later D15 or a 160 power unit. Kip
