Clodhopper Pete
I finally got the clutch put in my D15, but the pedal free travel is a bit further than it should be, and I am out of threads on the clutch adjusting rods. The adjusting screws for the release levers on the old assembly were cranked right down on the stop nuts, but the ones on the new assembly are out about an eighth of an inch. Can I tighten those adjusting screws through the observation hole without causing a problem, and will that reduce the clearance between the release bearing and the release levers.
Thanks for any advice.
Pete
Pete
